panelview 1000 to slc504 via AIC+
sparksy@gage
Oct 2016
perth
28
Thanks for the replies following my initial post Re connecting via serial to a DH485 PV1000
We have now found a 1761-NET-AIC and a 1761-CBL-AS03 cable that i hope will enable me to use a Panelview 1000 271-T10C3 to interface with a SLC 504.
Which cable would I need to connect the AIC to the SLC and how hard would it be configure. I have tried various driver on Rs linx to try and connect directly but with no luck
Thanks for any help
Wayne
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
214
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,139
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
452
