PanelView 1400E CRT Replacement?
mrdegold
Mar 2003
croydon pa.
80
It seems that over the weekend we lost the CRT on a PanelView 1400E (Cat#2711E-T14C6 Ser.A).
Has anybody used any of the LCD "drop in replacements"? I wanted to try to get a feel for if it is as easy as they show on youtube.
Also I'm hoping that someone can help me out and created a .PDF file of the PanelView 1400E program for me to use as a Reference. If you could PM me I will email the File. The Forum will not let me attach the file to this post or I just can't figure it out.
Most of the panelview operations are completed using a plant scada system and not the PanelView. We use the Panelview as more of a backup and for some more obscure functions.
Thanks for the Help
Michael
Update
I found a copy of the software and a copy of the program. I printed a hard copy for a reference.
I would still be interested if anyone has replaced the CRT with a LCD??
thanks again
vjtx,
Did you have an issue with the LCD being a lower resolution than the CRT. I just loaded an application from a PV 1400e CRT to an LCD version and got a mistake error.
" Mistake application requires a higher resolution panel"
Do I have to make a change in the software?
I would also like to know this. We have a PanelView (cant remember the number) and the backlight has failed rendering the CRT unviewable.
EDIT: Thinking about it, it might be a LCD PanelView already hmm
As it turns out our application had been set up for 800x600 res. The LCD replacement was 480x640 res. We were able to get into the application and downsize. We are having to redo graphics as some buttons were off the screen. Check the resolution on a screen you may buy off of the internet. The dealer I bought from had no idea.
Thanks and good luck
jfrey412
I ended up not doing anything with the panelview. My plant has a plant wide scada system that has been in place for sometime. The majority of the functionality of the panel was already being done through the scada system. I ended up migrating the remaining functions that were left to the scada and just powered down the 1400E.
Sorry I could be more help.
Michael
My CRT has gone out on my panelview 1400e, but all communications and controls are still functional through the function keys. Of course, for...
7,165
Just wondering if anyone is a master crt guy who can help me fix the crt part of a panelview 1400E. The screen is going dim on a unit that is...
6,114
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
313
Hello everybody, I am working on a project where the customer has several panelviews (PV1000e, PV1400 standard, PV1400e) which have model numbers...
1,724
