Panelview 1400E firmware upgrading
Deer
Jun 2002
124
Hi friends,
I meet a problem today in my customer where they use Panelview 1400E and I can't give them a solution to solve it.
Panelview was corrupted and need to upgrade the firmware.
The problem is, how to upgrade the firmware if Panelview can't display TERMINAL CONFIGURATION when key was changes to Configure mode?
The screen always display message either RUN or CONFIGURE key position.:"error #208 eeprom image is corrupt", APPLICATION LOADER FAILURE, FIRMWARE NOT FOUND"
As I knew, to upgrade panelview firmware you need to enter the Terminal Configuration and choose Upgrade Firmware (F12).
In this case I can't do that.
Somebody have idea?
Thanks in advanced
Deer
Scott,
Try starting a new thread.
Remember give as many details as you can, such as part numbers and revisions, what you are trying to do.
The more details you give the more people on here will want to help, and no doubt you will find an answer.
Mark
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
281
Hello everybody, I am working on a project where the customer has several panelviews (PV1000e, PV1400 standard, PV1400e) which have model numbers...
1,708
I have been given the task of upgrading our (anicent) PanelView 1400e 's that we have on site, with PanelView+ (1200 or 1500). I have the *.PVD...
1,918
Panelview 1400E ser E 2711E-T14C6/E, during boot up it says "waiting firmware download from PCMCIA card or serial port". I connect from the laptop...
3,638
Hi I have an Allen BRadley Panelview 1400e 2711e-k14c6 I'm trying to load the application from another terminal [same part number] from a PCMCIA...
1,512
