Panelview 1400E problem
jrs2563
May 2003
27
Howdy..this msg concerns a problem that has developed with my Panelview 1400E Panelbuilder 1400E software. I am developing several
program packages simultaneously on a Plc 5/40e, plc 5/20e and the Panelview. A couple days ago my PC froze up, after getting that fixed, reloading win98SE, getting linx to work again, everything now works except I keep getting the following error when I try to open
my Panelview application:
"Panelview 1400E Problem - Error in Synchronizing Channel 1.
Cause: Network Type 'Remote I/O' not installed."
Ive never had to install this "network type stuff and Im not sure where to do it...I can't get anything on the panelbuilder software itself except download upload (which work fine) and open an application. I can upload and download, just cant look at any program on the PC. Help! Jim Schroll
I found an A-B Knowledgebase document that describes that specific error. If you reinstalled the OS, I'm not surprised that PB1400e malfunctioned.
The fix looks simple, though:
Knowbase document G17430
The fix might be version-specific; if you don't have version 5.11 then give Tech Support a ring and get the right file to fix this error in your version of PanelBuilder 1400e.
Sorry to be late in replying Ken, but I wanted you to know that indeed
your post DID solve my problem. Thanks alot for checking this out for me. Jim Schroll
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
281
Hello everybody, I am working on a project where the customer has several panelviews (PV1000e, PV1400 standard, PV1400e) which have model numbers...
1,710
I have been given the task of upgrading our (anicent) PanelView 1400e 's that we have on site, with PanelView+ (1200 or 1500). I have the *.PVD...
1,920
Panelview 1400E ser E 2711E-T14C6/E, during boot up it says "waiting firmware download from PCMCIA card or serial port". I connect from the laptop...
3,640
Hi I have an Allen BRadley Panelview 1400e 2711e-k14c6 I'm trying to load the application from another terminal [same part number] from a PCMCIA...
1,513
