PanelView 300-downloading program
Dumb question maybe..I do have a 1784 series B PCMK card---using a 1784PM4/B cable.Is there a different cable i can purchase or is the flash card or the 1747-UIC the way to go. I'm planing on trying the flush later on today when things settle down.Thanks
If your going to have to deal with it a lot, I would get the 1747-UIC...
Actually, I say 1747-UIC either way. Longterm - Buy it, Short term - Borrow it.
I agree with TW.
The cable you have has a RJ45 connector not going to work with the RS232, as you know. I don't think they make a cable for a RS232 port for your PCMK card. See pdf below.
If you do have the 1784 PCMK card you will need this cable:
1784-PCM5/B which is a DB9 at the other end (comes with a 9 pin DIN adopter as well for the 5/04s).
I'd go with the suggestions of others here though for long term.
Get the UIC.
Get the UIC.
No,no thats for DH+ devices.
Finally go it to work. Deleted all drivers--installed 1 at a time
AB_PIC-1----NO PROBLEM
AB_KT-1-----NO PROBLEM
AB_DF1-1-------PROBLEM
So all I need to do is remember that I can't have AB_PIC and AB_DF1 running or trying to at the same time. Don't know why this is but that's the way the cookie crumbles. I do appreciate all who helped and took the time to post............Terry
Its because they are both trying to use the same port.
Glad to here you got it working.
Having a difficult time downloading a application to a 300 Micro Panelview. It does not recognize the Panelview. What procedure would you...
7,066
I am getting communication problem of downloading panelbuilder software 32 from my pc to panelview 300 that is intefaced with SLC 500.. I am new...
4,807
I am having pvc300 with me. I created my new program in ccw. The issue is that after clicking discover in ccw my hmi is not showing up there. Any...
146
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
223
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,159
