PanelView 550 Touch Screen Grid Defaults
plcsales
Guest
P
Is there anyway to adjust the default 8 high x 16 wide PanelView 550 touch screen grid? I want to try and fit just a couple more touch sensitive numeric entry points on the screen. I would also like to make my page change buttons about 1.5 times the standard default touch grid size. Is it possible to adjust the touchscreen grid or is this a function of the hardware that is fixed.
PS I've looked at the AB manuals and they review how to adjust the gris size. However this only effects where graphics snap to in PanelBuilder 32, not the size/position of touch senitive items like buttons.
You are out of luck, the touch screen grid is a hardware function and can't be altered in Panelbuilder (you can see the cells if you look at the terminal at an angle). The grid settings you can change relate to the drawing grid not the touch grid.
If you want more touch cells you could always upgrade to a panelview 1000.
You can also view the touch grid settings in the PanelBuilder software. The other grid you mentioned is the "snap-to" grid. It is helpful for placing and aligning objects but the touch grid will show the locations of the actual touch cells. I often turn off the snap grid and display only the touch grid.
Click on View and then Touch Grid to see the touch grid layout. As others stated, you cannot alter the touch grid settings as that is a function of the hardware.
OG
I've got a cracked screen on a Panelview 550. Will AB just sell me the screen or does anyone know where I can get just the touch screen? Thanks...
4,256
Hi, I hope you can help me with my problem with a panelview 550 touch. The panel was used before for another plc and therefore it want to...
5,689
Hello everybody, I'm try to download a program from my laptop (panelbuilder) to my new panelview 550 touch but i get error "the download port are...
3,610
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
350
Client has multiple spare Panelview 550 (2711-T5A10 L1 PV550 Touch Devicenet)...
688
