Panelview 600- "685 File Access Error"
akash11132
Jun 2017
Sydney
45
I am trying to fix an issue with PV600 standard terminal. After changing one alarm message description and downloading to the terminal, I started getting this error on top of all pages. All HMI values are getting displayed except for the alarm log.
Regards,
Akash
In this context, the word "file" means a PLC "data table file".
B3 is the default boolean data file, N7 is the default integer data file, F8 is the default floating point data file, for example.
The most likely explanation is that one or more of the PanelBuilder tags that are configured to read PLC data table files got mis-addressed to a data table file that doesn't exist.
This is also common if you address an element of the file that doesn't exist, like addressing N7:100 when the data table file is only 100 elements long (0-99).
Thanks Kuulkuum and Ken for suggestions. Yeah, I was under the impression that data files address (in PLC) might have been mismatched or unavailable. However, problem was with PanelBuilder version v3.83. This project was originally built on panelbuilder version v3.80.
So, I installed version 3.80 on windows xp VM and modified the project changes to the file. Download from panelbuilder 3.80 solved the 'File access 685 error'. Strange.
All, I have panelview 600's in my shop and have the same program on each one which is used on an identical machine. When I updated the program...
3,434
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
223
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
465
Hello, Friends Please someone help me find right cable to communicate Panelview 600 (2711-B6C9) to Micrologix 1200 (1762-L24AWAR). AND any advice.
271
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
655
