toddp65
I developed and set a panelview 800 program for our glycol system last year.
It's been working fine, I just needed to make some logic changes to the micrologix and the PV800.
Upon uploading the program and making the changes and then downloading, I received an incompatible version mismatch, project not same as panel and unable to load. Panel is in 4.11, project is 5.11 (project WAS 4.11 when I uploaded it for backup).
I was stuck with an empty project until i could find a backup to save the day. If you make one change and save that program CCW automatically changes the version on you. I feel it shouldn't change the version unless you intentionally do it. I may have updated CCW in the last year, probably the cause.
I don't see a way to revert the program back to 4.11. It only shows the same version.
Thoughts anyone?
Thoughts anyone?
