PanelView 900 protocol conversion
jcrummy
Jul 2008
Edmonton
Hello,
I have an Allen-Bradley setup with an SLC 5/04 and two PanelView 900, one running on DH+ (2711-K9C8X) and one that was running on DH485 (2711-K9C9). I've replaced the panel running on DH485 with a more modern terminal (part of a series of upgrades we did on the client's system), so I now have it as a spare part.
I would like to be able to leave the terminal that was running DH485 as a spare for the first terminal. My original hope was that I could program the screen to act the like the first one, and all the guys would have to do is swap out the daughter boards on the panels to give the spare DH+ capabilities. After looking into it its looking like that is not a possibility.
My question is: Does someone know of a way to change the firmware on the panel to give it DH+ capability? If not, is there a way to put the DH485 screen on the DH+ network and make it work that way.
Just as an FYI: The screen on DH+ is a fair distance from everything else with only the DH+ cable running to it, so changing wiring is not too feasible.
Thank you
Not a very hot project, huh...
I doubt it. Never tried, but they're not compatible. Check with AB.
Absolutely, no. The comm protocols aren't even closely related.
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
1,010
Panelview 900 communicates with SLC 5/03 PLC. When I upload the program from the panel, some buttons have the address B3/306, B3/304 etc. However...
2,458
Panelview Part #: 2711-K9A8, that communicates via DH+ to a SLC504. There are two PV's on the network. One has lost its application. Downloaded...
1,977
A question for the hive mind, i have a Panelview 900, monochrome non touchscreen model. On power up, i get error 34 which relates to an extended...
2,181
I have those old early 90's panel views in my plant. I use an old XP image to get the program back into them but maintenance wanted a way to do it...
2,388
