PanelView 900 upgrade
rbkief
Jun 2004
banghead
Please help me! :confused:
Before I begin, I would like to say hello to all. I would like to also add that I am new to PLC programming therefore my knowledge is very limited.
Now, my palletizer currently use panelview 900 and would like to upgrade to 1000.
After uploading the current file (program) from the pv900 to my pc (using direct rs232 cable) using PanelBuilder32 3.80 version, it advice to convert file to newer version==yes; but then fail to load the file after convertion.
Display something like "Cannot load filename.pva file maybe corrupt or the disc is full".
Thingking, no problem I have a backup file.
Next, plugged in the pv1000 and attemp to download 97x_727.pva to pv1000 using rs232. Now..I have other problem. I can upload but cannot download to the pv1000 rio.
Just my luck. Puzzled with the result, I went to alternet route to my troubleshooting. Thus, got another pv1000 ethernet and connected to the network and try that. Well, I guess some of you may already know the outcome. Yup the same thing! I can upload but cannot download. :confused: banghead
Thank for your time and respond in advance. :unsure:
hello
Last time this happened to me it was the wrong version of panebuilder.
I was using v3.7 and the panelview had been built using v3.8, it would upload but i could not edit it. Upgrading to v3.8 cleared the problem.
The error message you get was exactly the one i got!
regards
kevin
rbkief,
Make sure you have the correct model Panleview designated for the application. Open your file in Panelbuilder and in the left hand Application pane, go to Application Settings->Terminal Setup, and make sure you have selected the correct model PV.
Good Luck,
Jeff
We have several PanelView 900s with RS232 and DeviceNet communication. We would like to be able to passthrough and download the panelview...
5,665
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
1,000
Panelview 900 communicates with SLC 5/03 PLC. When I upload the program from the panel, some buttons have the address B3/306, B3/304 etc. However...
2,456
Panelview Part #: 2711-K9A8, that communicates via DH+ to a SLC504. There are two PV's on the network. One has lost its application. Downloaded...
1,977
A question for the hive mind, i have a Panelview 900, monochrome non touchscreen model. On power up, i get error 34 which relates to an extended...
2,173
