Panelview C600 - Need help BADLY
Fredlaroche
Oct 2013
Chicoutimi
41
Hey guys, I've tried everything here and I'm in a dead end. I'm in korea for a comissionning contract and my PV C600 T6T is giving me nightmares
Here's what happed:
Yesterday I changed the IP of my PLC and my PV to get them on the customer network.
Everything was working Fine everything was communicating well and I was almost done testing.
I leave everything on overnight, go to the hotel and get to sleep
Only to come back this morning with the PV completly gone from the Network. Impossible to ping it. It doesn't read any thing from the PLC.
I have tried giving it it's IP adress again but it won't let me change any system tag (when I try to edit the Subnet, the IP, ANYTHING, it gives me warning 2058 (the one where the data cannot be wrtting to a tag).
What I have tried so far is:
Reloading the application... Exact same problem.
Reseting to factory default... Exact same problem.
Updating firmware to latest... Exact same problem
I have no Idea what to do here. Anyone ever had something like that?
As for the status of the connection, the leds are blinking irregulary on both the PV and my Switch. Also, the cable tested fine.
If anyone thinks of something, let me know
Allright guys, if anyone ever runs into this thing, just forget about fixing it. I've spent hours on the phone with tech support and the initial reaction to the problem I am having basically told me what I wanted to know: Panelview is dead, replace it.
Hope this helps anyone who ever runs into this.
Fredlaroche said:
...Panelview is dead, replace it...
That's little consolation when you're in the back of beyond! 🔨
I don't know if this is relevant to your PanelView's application, but this apparently is the reason for Error 2058:
58474 - PanelView Component Error 2058
Access Level: Everyone
George
hello frnds, I need some help on how to write a recipe in Panelview C600 HMI, using Panelview explorer.The recipe has five parameters like Ring...
1,921
Have a C600 Panelview that the display went out in it. It still has the configuration in it and the equipment is still running. Believe it is just...
1,603
I have a working collection of applications for the PVC C600. the setup is one pvc600 connected to a DH485 network with two micrologix 1200's...
1,571
Hi Guys, I have a Panelview C600 2711C-T6C that one of our clients have and they wont to remote access the screen is there anyway you can do this...
2,904
Afternoon folks, Anyone have any idea where I can find the download for USB RNDIS driver to connect to a C600 Panelview. Looked everywhere and...
10,237
