Panelview Config Screen (Topic 1 of 3)
Alright, I can't say for touch only screens as I've only used keypad only versions but the way to dump all the memory is to power up the unit; after the test 32 (or maybe 33) which is the keyboard test, press and hold the lower leftmost and upper rightmost keys simultaneously. Eventually you will get a message telling you hoe much memory the unit has and everything will be wiped clean (just the application, no the firmware).
I did have to do it a couple times to get it to work (maybe I wasn't hitting the keys close enought thgether?)
If you don't wait until after the keyboard test, you get an error that a key is stuck and no erasing takes place.
The thing in my application that locked up the PV 1000 (DH+) was that I had a reference to a variable in an alarm message. (Don't remember the type of reference). Panelbuilder verified everything OK but when the PV would reset after download I'd get an error number (sorry, don't remember that either) and the whole thing would be locked up.
Maybe someone else will chime in on how to dump the application on a touch only screen.
I've been searching for a way to do this for the past day or so due to an archaic/used PV1000 we've had in stock for years. Thank you all!
Hi all, I was uploading from a panelview plus 600 to back up the file and there were 6 runtime files in the memory. I need to know which one is...
2,873
Hi I have a panelview 1000 (2711-T10C3) on a machine with an app that runs when the screen is powered up. The panelview is a touch screen, with...
4,651
Hi all, Just checking to see if anybody out here has some screenshots of the Terminal Configuration Screens that I could use for putting a...
1,606
Hi, im trying to go to the config mode on PanelView Plus 600 series A rev. B, but have no luck. Somebody downloaded his own application with no go...
53
103,383
Hello All, I have a panelview plus 1250 I need to make changes to but I am not the original programmer. The previous programmer did not add a...
28,201
