Panelview configuration screen
sweety616
Jul 2005
New Jersey
36
There is no configuration screen on my panelview 600 2711-T6C20. Is there a way I can do it from my program in panelbuilder32?? I need to be able to access config settings.
1. You can create a screen selector to go the the config screen and password protect it if you want.
2. Or if you would rather not have the configuration screen accesible from the Panelview you can reboot the Panelview. While it is on it Blue boot screen you will see numbers incrementing. When it hits 32, I think, a white box will appear in the bottom right corner. Press it until it goes away. You actually only have to press it once but it can be hard to hit. This will bring up the config screen
How can I "You can create a screen selector to go the the config screen and password protect it if you want". Can you walk me thru the steps
thank u
Can't get picture to work
Go to Objects, Screen Selecters, Goto Config Screen
Edit - Got picture to work. This help?
I don't know the 600 touch screen units, but on our 2700-B6 (both touch and keypad entry), any time the unit is on (fully booted), you press the left and right arrow key simutaniously to access the config screen. (Same with our 550 Panelviews.) Does the touch screen only units have the left and right arrow keys available on screen?
No, there is no method I know of when you don't have the keypads. I use the little white square method TW pointed out.
To access Configuration Mode on keypad terminals:​
If an application is running, simultaneously press the Left and
Right arrow keys on the terminal keypad.
To access Configuration Mode on touch screen terminals:
press the GoTo Config. Screen button on application screen or
press the filled box in the lower right corner of the screen during powerup.
No, just goes to the config screen. Also should note that if you have password protection setup for the config screen pressing the white button does not bypass that. You still must enter your password
Hey Guys, After a firmware upgrade and the addition of Viewpoint firmware on a panelview Plus 6, it will randomly promp the operator for a...
1,662
Hello friends. I could really use some help with this one. We have a machine that's using a Micrologix 1400. We also have an HMI connected to it...
12,888
Ocasionally if you cannot shutdown an application in a AB panelview plus and rebooting reloads the application it can be difficult to overcome...
2,544
Hello, We just recently bought this new PanelView Plus 7 - 2711P-T10C22D9P SER B and when we are trying to put the IP Address. Follow the...
1,691
Hi,Guys: I am new to this forum. No "white box" showing at the boot. We want to edit .mer file, but we don't know PanelView Plus_6 1500 firmware...
5,935
