Panelview error 634
Jonesca9
Jul 2009
Cheshire
19
Hi all,
A customer has an existing Panelview 600 that has apparently operated for some time without fault but has recently started locking out with "error 634 ‘Read Timeout IP:10.50.190.150, Path 1 0; Tag:pV3_String[10.Data,0]".
The same message is always reported and occurs daily. My question is : should I be investigating communication issues or could the string tag cause such an error? The current Interscan Delay for the Panelview is 200ms. The software associated with the tag appears quite complicated :oops:
Model# and firmware of the PV?
What PLC & firmware?
I would start with communication issues.
Does it happen every time the screen is opened? Do you ever get valid string data?
Did something change with the PLC program or the networking?
Updated firmware, new periodic/motion tasks, deleted tag, extra computers/devices reading data from the controller?
If the tag gives you valid data sometimes, then look at the network & controller usage. Might just be overloaded with too many requests.
I replaced an existing PanelView 300 with a new one. It is the same style as the old one and I took the file directly from the old one and put it...
1,832
I have a PanelView 550 and am communicating with CompactLogix conroller. I'm wanting to use the status tag for the screen number in ordre to make...
2,304
Hello, I've done a search on the forums and found out some information about the 634 timeout error that I'm getting on the Panelview. Our...
8,002
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
721
I am assisting with an old PanelView Standard 600. The PV displays an error 24 on autotest. I am reading that this is some kind of Firmware...
1,164
