Panelview factory reset
A_G
Jul 2014
MA
370
My Panelview Plus 7 Performance with firmware v10 gave me this error message: "Error #2: terminal software stopped responding, select recovery options". After talking to Rockwell tech support, they said this was a Bios error and recommended to do a factory reset of the Panelview and download the latest v10 firmware from the Rockwell website. Anyway, this system is supposed to ship soon, and I don't really want to do this in case it causes even more problems down the line. At least right now, the Panelview seems to be running ok for a few days. On the other hand, if this issue happened once, it can happen again. Any advice is appreciated! Has anyone had a similar issue before, and what did you end up doing?
Based on your comments about the terminal "losing" its *.MER file, and now a low-level failure that might indicate an inability to run its filesystem.... order a replacement. Chips fail, and even though Rockwell does pretty good burn-in on PV+, it's not impossible that you have a bad SSD chip or interface.
Kindly, anyone knows how to factory reset this Rockwell hmi? Could not find anything meaningful in the manuals! Allen-Bradley 2711P-T10C4D1...
2,056
All, I have recently factory reset a panelview plus 700 and now i cannot obtain any communication though RSLinx Enterprise Communication in...
3,145
can anyone help with trying to connect a panelview plus 7 to a pc i made a ip address for the panel view i ping it from my pc and its seeing it...
20
3,537
Hi, guys. I get an old AB PanelView 1000 (2711-T10C15, SER: D) from somewhere. But there is a password to stop me accessing to configuration...
17
6,642
A client of mine has a contract to rebuild and modify four machines, each of which has a Compact Logix PLC and a PanelView Plus HMI. Last year we...
16,983
