PanelView Graphic Question
gizmo
Aug 2002
95
I want to make a numeric display (that shows a timer counting down) to only be visible when timing.
I've got the bit I want to use to make the timer visible and I have the timer value displayed.
Could some please tell me how to make this happen.
You could try a multistate indicator instead of a numeric display. The indicator will be tied to your bit. State 0 will have no text, make the colors or that state match your screen background and it will be invisible. For state 1 right click on the message text and use enter an embedded variable. Use your tag for the timer accumulator. I haven't tried this, but it should work.
When I right click on the message text and use enter an embedded variable, every option(date,time,numeric,character etc) is grayed-out.
Anyhelp on why?
Thanks Again for you help!
You will need a multi-state indicator with two states. Note that they normally default to 4 states so you will have to edit the states and delete two of them.
In Panelbuilder 3.8 the workflow is:
  • Select Objects/Indicators/Multistate from the main menu bar
  • Place object on screen and size as desired
  • Double click object to open properties
  • Select the States Tab
  • Highlight two rows (like you would in Excel) and hit the <del> key to remove them
  • Erase the text "ST 0" in State 0
  • Highlight the text "ST 1" in State 1/Right Click on the Text/Select Embedded Variable/Variable
  • Enter tag and disply properties for your countdown number
  • Click OK
  • Go Back to the Properties Tab for the Multistate Ind.
  • Select the Single Bit radio button
  • Select the trigger state 0 radio button to match the function of your display bit
  • Select the Tag for your display bit
  • click ok to close the properties window
  • Select state 0 and change the object and fill colors to match the screen background colors (thus, when this state is active, the indicator is invisible)
I think that covers it all.... :)
Follow up
That worked great!
I sure appreciate everybody's help/advice.
Man, I love this site.
Thanks,
Again
Version 6 I want to have a password enabled button. How do I do this? Do I have to have logic in the PLC to do this? Thanks
1,667
I have a Panelview comp c600 graphic terminal. Part # 2711c-t6m (ser c) I saved the file to a USB flash drive. When I downloaded it to the new...
2,422
Hi All, Im new here and there seem to be some very knowledgable people on here so I thought I'd ask you all a question... We have been having...
5,348
Hi all, I'm working on an HMI application for a Panelview 1400 and I want to upload my graphics so I can see what they look like on screen, test...
4,004
