PanelView OPC
boneless
Feb 2008
OKC
1,628
Hi all!
Quick question.
I have duplicated a PanelView project. The HMI communicates to a Siemens PLC so I am using KEP OPC.
For now I have copied the OPC setup.
If I change the OPC name, from Triumph to something else, all my tags will be wrong. Is there a way to change all my tags at once? It is only the base (Channel1.Triumph) that would be changed.
It is not a big issue, but I would like to use the correct name, in case I get connection issues pop up in the screen.
In this case, I think the ordinary Search and Replace feature will work.
Find: "Channel1.Triumph"
Replace With: "Channel1.Victory"
You aren't actually changing any Tag names, just part of the text string in object Connection fields.
Find and Replace should be in the top level toolbar, or use the top level menus to select Tools -> Replace.
You don't have to have the Displays or the Tag Database open to use the Find or Replace features. The filtering to limit them to specific displays is weak, but you can do some "Find Next" searching if you only want to do part of the project or a specific display.
Do a Find All first so you can see all the places that your "Channel1.Triumph" path segment is used.
hey guys. i am having an issue and maybe somebody here can help me out with it. i have a panelview plus that i am trying to get to read kepserver...
3,489
Hello Everyone i'am kinda new to this stuff. Anyway so i have a project that I have to set up the AADvance as my PLC, Kepware as my OPC and...
2,626
I've just been told by AB/Rockwell support that Panelview plus 1000 (FT ME 8.1) won't support OPC using the Kepserver. Is that right - I've...
1,496
Hey guys, I'm in a pretty weird situation and I'm looking for some input. Without going into too many details, I need an Allen-Bradley Micro850...
12,035
