Panelview Plus 7 Perf.- When downloading a runtime should it reboot?
Aug 2016
Virginia
343
Good Afternoon ,
I have a Panelview Plus 7 Performance HMI. I made some screen changes and created another runtime. I downloaded to the Panelview Plus 7 , expecting it to re-boot , but it did not. What did I do wrong ? I am sure I missed a checkbox some place. That is normal for it to re-boot , correct ?
Thanks so much for you help.
Using that checkbox is the only reliable method I know about to force the terminal to run the just-downloaded *.MER at the next reboot.
I don't even experiment with the Terminal Settings methods anymore; I just do another download with the box checked when I know I have an application I want to run.
Thanks guys ,
I heard that with the Panelview Plus 7 that you can add videos to applications . Is that true ? If so , how is that done ? I would like to put some training videos on some of our HMI's.
Thanks again , and have a nice Easter ,
If you have a "Performance" model, it has both a speaker driver output (screw terminals on the back) and Microsoft Video Player 9 installed on the Windows CE 6.0 operating system.
There are a handful of Knowledgebase documents about using the App Launcher ActiveX to run the PDF viewer or the video player.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/835137
I cannot get the PanelView to talk with my network. I understand that PING is disabled. I cannot see the PanelView via RSLinx. Any help is...
7,976
Using FT View Studio v12, I am getting an error when trying to download to (and also upload from) a PanelView Plus 7 Perf 10" (firmware version...
15,589
Hi, The model for this HMI is 2711P-T10C22D9P. In the run time file setting I select panelview plus 7 10". When the HMI start, it will go though...
2,154
89
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
56
