Panelview Plus 7 Perf.- When downloading a runtime should it reboot?
Aug 2016
Virginia
343
Good Afternoon ,
I have a Panelview Plus 7 Performance HMI. I made some screen changes and created another runtime. I downloaded to the Panelview Plus 7 , expecting it to re-boot , but it did not. What did I do wrong ? I am sure I missed a checkbox some place. That is normal for it to re-boot , correct ?
Thanks so much for you help.
Using that checkbox is the only reliable method I know about to force the terminal to run the just-downloaded *.MER at the next reboot.
I don't even experiment with the Terminal Settings methods anymore; I just do another download with the box checked when I know I have an application I want to run.
Thanks guys ,
I heard that with the Panelview Plus 7 that you can add videos to applications . Is that true ? If so , how is that done ? I would like to put some training videos on some of our HMI's.
Thanks again , and have a nice Easter ,
If you have a "Performance" model, it has both a speaker driver output (screw terminals on the back) and Microsoft Video Player 9 installed on the Windows CE 6.0 operating system.
There are a handful of Knowledgebase documents about using the App Launcher ActiveX to run the PDF viewer or the video player.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/835137
I cannot get the PanelView to talk with my network. I understand that PING is disabled. I cannot see the PanelView via RSLinx. Any help is...
8,144
Using FT View Studio v12, I am getting an error when trying to download to (and also upload from) a PanelView Plus 7 Perf 10" (firmware version...
16
15,669
Hi, The model for this HMI is 2711P-T10C22D9P. In the run time file setting I select panelview plus 7 10". When the HMI start, it will go though...
2,168
80
Replaced overlay and glass in HMI but now I can not calibrate the touch screen any suggestions.
73
