Windows CE doesn't use drive letters, but it does use backslashes to designate storage locations.
\Windows is a directory on the main filesystem which, as the name suggests, holds the Windows operating system files.
You probably shouldn't store user datalogs there. Put them in \Temp or \Logs if they're going on the main storage device, or into a directory on a removable storage device.
\USB Storage is the root directory of the first USB storage device connected to the terminal.
\USB Storage2 is the root directory of the second USB storage device connected to the terminal. The order of connection is all that matters; the port or hub they're connected to does not.
\Storage Card2 is the root directory of an SD or CF card inserted in the outside slot of the logic module of a PanelView Plus.
In general when you are storing data using the DataStore Plus ActiveX control, you should create a folder off the root directory of one of the removable storage devices, like \Storage Card2\Logs
It sounds like you're just trying to copy all the contents of the directory \Windows\logdata\LineD_DataLog1 onto a USB storage device.
The command line for that should be
copy \Windows\logdata\LineD_DataLog1\*.* \USB Storage\
There is a space between last asterisk of the source filename wildcard and the first slash for the destination path.
