Hello,
My PanelView Plus 1000 can not see my tag HMI_Test in my RSLogix 5000 program. In FactoryTalk my application can see the tag but when on the PanelView it cannot. I believe the communications for Design and Runtime are setup correctly, they both point to the controller through an Ethernet switch into the Ethernet on my plc. I do recieve an error however when I create the runtime application and think it may be cause because I am using a Compact Guardlogix controller.
I have attached screenshots of the communications just to confirm as well as the error readme.
Any help would be awesome guys!
Thank-you
Thank-you
