Panelview plus - read string tag from SLC-5/05
JimSandberg
Nov 2008
E-Town
I have countless times tried to read a tag inside my SLC-5/05 with my panelview plus 1000.
I am trying to simply display the name of a product. It's nothing crutial but I can't just give up now.
Here are my details:
- A datafile called A39 in RSlogix500. The string i want to show is by length 5 bytes, starting from A39:0. (tag is called RCP_PARA_00)
I have no trouble importing this tag to Factorytalk view. My only concern is that it only imports as an analog type and the tag data is undefined.
Either way I can create a String display field and connect this tag to it.
What happens now is that I can only see the data from the first byte.
And so later I tried creating a new HMI tag from the factorytalk view software and define it as string (instead of analog) and to set the lenght to 5.
I then link this tag to A39:0. But it still comes out with the same result as before.
I'm guessing I manage to screw up somewhere along this way but I don't understand what I'm doing wrong!
Can someone explain the procedure of creating a string tag that can be connected properly to the SLC-5/05?
Thanks in advance
Regards,
Jim
From memory: look for something called Character Array to reference ascii addresses. Note that each "A" element is two characters.
Faiilng that, change the SLC to copy the "A" characters to a ST data element and read that as a string within factory talk.
I can't really find anything referring to any array in factorytalk view.
My big question is how do I reference A39:0, A39:1, A39:2, A39:3, A39:4 altogether in one HMI tag?
I'd first go create a tag in the tag browser in factorytalk view.
Name it "Name" for example.
Set the type to String
Length to 5
And then when I come to the address part, I just don't know what to write in this box.
I can write A39:0 but that only causes the string display to show the 2 letters that are in that byte.
Appreciate the quick answer!
EDIT: Ok now looking in RSlogix500 I wonder why oh why am I trying to read from an ascii data file when I could be reading from a string file instead?
Will investigate results!
Hi, Rockwell beginner here, so I have been trying to set up an HMI Screen in Panelview PLus 1000, which would tell the customer if a link is...
5,534
Hello One thing I want to ask is. I have been using the panelview plus 600, but I have seen that it is possible to read it in version 7 or later...
1,243
87
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
56
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
86
