WireBiter665
I have a curious question and I can't seem to find any information on it. I'm hoping I'm just overlooking something simple.
I have 4 machines that all do the same thing. Each machine has its own ControlLogix PLC. Each machine also has its own PV Plus. I need to make changes to the HMI programs. Since all are going to be the same, I'd like to just change one of them and download to each PV Plus. My issue is when I do this, either with "Replace Communications" checked or unchecked, it changes the Shortcut on the PV Plus to interface with the wrong PLC. Then I have to reconfigure the shortcut on the PV Plus to point to the correct PLC. These are all on the same network so I can't set the ControlLogix PLCs to the same IP address.
The question is, how do I update the HMI program in the PV Plus without changing the PLC Shortcut?
