Panelview Plus Firmware and FTV V7.0
d_tech
Apr 2015
Williston ND
Hello all!
Is there a resource that can tell me if my Panelview Plus 700 and 1000's firmware version will be compatible with my version of .mer file that i created?
For instance. My PVP 1000 has Version 5.10.2.9. I used Factory Talk V 7.0. Can i run the version 7.0 in that HMI? I have Version 5.10 running in them all now, I just brought all of the .mer files up to Version 7.0 from the old 5.10 (32bit).
Thanks for any help!!!
The old PV+ cannot run a new-version Runtime project.
But the new version Studio can create Runtime projects that are suitable for that older firmware.
When you create the Runtime, you'll have a selection of what terminal firmware you want to create the Runtime files for. It ought to go back to version 3.2.
Right. I am trying to do away with my old 32 bit and get some of these old terminals updated though, so like a controller i can flash a PVP 1000 up to newer firmware cant i?
We have so many versions of FTV, RS 500, RS 5000 and Studio files in this plant and i am trying to bring everything up to a level where we have some uniformity....
Versions are tough to manage since there are always new versions coming out. Best approach often is like what you do with Logix systems, pick a revision (of your .mer) and use that everywhere.
If you create a rev 7 .mer it will load on any PV+ rev 7 or newer. They don't have to match as long as the PV+ rev is newer than the .mer rev.
OG
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
482
The panelview in question has been installed for over 2 years with no issues. Our facility has an extensive SE installation with a handful of ME...
1,263
My panelview runs firmware 9 just fine. I would like to understand the justification to upgrade the firmware to the latest. I've been asked to do...
1,635
Hi all, I'm still learning so apologies for silly questions. I have developed a HMI runtime on Factorytalk View Studio V13.00. I have gone to...
3,023
Hi there everybody, Which firmware is the PanelView Plus 7 12" OIT (2711P-T12W21D8S) compatible with? Is there an online tool or table that...
1,645
