Panelview Plus HMI key assigment
davidvu
Apr 2015
CA
19
A display has a button assigned to key F1. There is also an active popup (On top type) that has a button assigned to key F1. Would pressing the F1 key actuate both buttons?
Also is there a way to assign the same key multiple times on the same display?
Thanks for help. I don't have access to a keypad PVP HMI to find out myself.
In the situation you describe, when you open the On-Top Display, only the object associated with F1 on the On-Top display would be activated when the user presses F1.
But if the On-Top Display is smaller than the display it covers and you have a touch+keypad terminal, you can still make the underneath display active by touching somewhere on it (the On-Top Display) will remain visible) and then the F-keys will activate the object on the active lower-level display.
Only one object per Display can be associated with a Function Key. If you try to assign more than one object to the same F-key, FTView Studio gives you an error message with the text "Unable to assign the key assignments: Two or more objects have the same key assigned."
My next question should have been: "what do you need the HMI application to do ?"
The inability of FTView ME to execute more than one function per user action has been a drawback since its inception, but the slightly-misnamed "macro" function can allow you to set several tags to values or expressions with a single button press on the "Macro" button. You just have to define a simple Macro file in the Logic and Control -> Macros folder in FTView Studio.
I'm trying to use the Create New User button on the HMI so customer has the option to add new users and passwords at the HMI. They dont have...
440
Hi, I have a PVP 1250 with ME station FW 6.0 I would like to upgrade it to ME Station FW10. I downloaded the FW10 from Rockwell site and...
2,321
Hi all, I'm still learning so apologies for silly questions. I have developed a HMI runtime on Factorytalk View Studio V13.00. I have gone to...
3,045
Hi, I just wanted to know the user administration in factory talk view ME. I have around 12 nos of HMI in a factory. Customer wants to configure...
1,133
I am working with a Micrologix 1400 and a PanelView plus Compact HMI. There are some HMI tags that are present in the HMI that is actively using...
2,735
