PanelView Plus not visible when browsing FTLinx
simonv
Mar 2014
UK
I've done a factory reset on a PV 7 Plus terminal, set the IP address and cycled power.
I can now ping the PV and can see it on RS Linx but its not appearing when browsing using FT Linx and consequently I can't download the application.
The ME station firmware is 10.0.9, FTView Studio is rev 12 and I'm using Ethernet/IP to communicate.
What have I missed??
If you can see it in RSLinx that suggests the problem is not with the PVP terminal.
Try deleting and recreating your driver in FT Linx; I've recently had occasional problems with FT Linx not wanting to detect things and that usually resolved it.
I will state the obvious first to get it out of the way...
Right-click on the Ethernet driver and if there is an option that says, "Start Browsing", select it. If it says, "Stop Browsing", do not select it, you are good. I have had cases where I just could not get it to see my device no matter what I did. When that happened, I manually added the device in FT Linx.
If you right-click on the Ethernet driver and select Add Device you will find the PV+ 7 near the bottom of the EtherNet/IP Devices category. Adding it manually seemed to sort of wake-up FT Linx to the device and I was able to talk with it. Worth a try.
OG
Many thanks for your prompt responses.
In the end I cycled power to the Stratix switch and that sorted it!?
87
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
56
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
86
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
93
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
136
