Panelview Plus screen number change from the PLC
bagged2drag
Mar 2011
Milwaukee
37
I'm sure this is an easy problem to solve, but so far I haven't found the solution.
I am looking to trigger a screen change using a word. I have used this function in other HMI's in the past, including older panelviews (using Panelbuilder32). Could someone point me in the direction to use this same functionality in factorytalkview for the panelview plus'?
I recall the old PV's required setting up an integer which you would move a value to to change a screen, and you would need to immediately move a value of 0 back to the integer to keep control of the screen at the operator side of things. I've searched and searched in factorytalkview (ok, maybe about 30 or 40 minutes) but cant find where to set this up.
I'm a robot programmer and do some PLC programming, but PLC/HMI are not my core competency. Any help is appreciated.
Regards
Kris:doh2:
In your factorytalk studio Explorer Window look for Global Connections. You will find it there under the Display Tab. Click the Help button from the Display Tab property page for detailed information on each function.
I have 2 PV Plus 7 screens used in the same system that both have touch screens that can be challenging to activate after they haven't been...
577
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
738
Any good idea how to dim the display on a panelview plus performance serie b, at idel. Screen saver is not supported yet I have don it in global...
2,235
New PanelView Plus 7 Performance Series B P2711p-t10c22d9p out of the box I went through the touch calibration screen and then to the "Welcome to...
4,901
I am having an issue where the alarm history on the HMI is zoomed way in. It is as if even though my font size is set to 6pt in factory talk ME...
2,784
