PanelView Plus 7 Performance Series B stuck on initial set up screen. Windows 10 IoT
Jemeu
Nov 2019
United States
New PanelView Plus 7 Performance Series B P2711p-t10c22d9p out of the box I went through the touch calibration screen and then to the "Welcome to PanelView Plus" screen. I then go to the password screen and it just loops back to the welcome screen over and over.
I got on the phone with an AB rep and he said to just return it and get a new one... I have been rebooting it while hold F1, shift-F10, CTRL+SHIFT and nothing. A-B Quality
Any solution to this?
There is a button, it is just unlabeled.
Edit: When you press the button, it reboots to the maintenance menu, where you can factory reset it.
Found it! Its very unlabeled
After you factory reset it, then get it all configured, you can return to this menu and back it up. That way, when you have to do this again, you can restore your backup.
This has happened to us twice in the ~two dozen we've setup. They don't like to boot with the thumb drive in, so I what I think happened is that at some point during the setup, someone left the thumb drive in, thought it was frozen and yanked the power. It was then stuck with the welcome screen infinite loop.
Yup, I had the welcome screen infinite loop and I didn't know how to factory reset it. I just did factory reset and it seems to be working properly now. I think the same thing caused it, but I had a keyboard plugged in instead of a thumb drive.
really strange issue. The panelview(2711p-T10C22D9P) will try to load an application and get stuck on "Starting Alarms". If I reboot the...
1,449
Hi people - I'd appreciate a little help/ information please. We have a new panel as per the title. When I come to downgrade the firmware (as...
1,398
I have a customer who has 20 of our systems using PanelView Plus 7 Performance Series A terminals. With how hard it is to find printer nowadays...
1,621
Hello Everyone, I hope we are all good! I have a strange one, and wondering if anyone has seen this before. When I look at the CSV Export Logs...
1,607
We're new to using the Panelview Plus 7 Performance Series B panels as the series A is no longer available. FactoryTalk Linx shows it as a yellow...
1,582
