PanelView Plus 7 Performance - CSV Export Time Stamp
celichi
Apr 2008
Greater Toronto Area
415
Hello Everyone,
I hope we are all good!
I have a strange one, and wondering if anyone has seen this before.
When I look at the CSV Export Logs for Audit Trail or Alarms, the time stamp is in UTC, which I get, this can not be changed, but what I noticed today, is that there is no seconds in the time stamp. Well there is, but every row is ,0 for seconds.
Is this normal or is something a miss here....
3,{[xxx]xx_xxx},xxxx,xxxxxxxxxxxxxxx \n xxxxxxxxxxxxxxxxxxxxxxx,0,FALSE,FALSE,6/14/2022 19:54,0,MheJkfGrmLB91OEayHB=bSilJn`LDu`j1NGi0J;~Lrd
Thanks in advance
Are you importing CSV data into Excel? Try opening the raw file on its own and adjust the time column for the correct time format.
For the record I do a lot of CSV exporting in my plant and can vouch you should have a seconds value.
Last thought. Do you have a screen or alarm update value set to a minute somewhere?
SOLVED!
Thank you very much Thumperbs for taking the time to answer my question!
I asked for the raw files direct from the HMI, and when I opened them in note pad, the seconds were there.
This should be a tech note on the AB KB, but I could not find this information.
For sure Excel is doing something to the csv files because after opening with Excel, the tamper detection failed as well.
This is related to...
21CFR11
21 CFR 11
Audit Export
CSV Export
Audit Trail
Audit Trail Setup
CSV Export Setup
PanelView Plus
really strange issue. The panelview(2711p-T10C22D9P) will try to load an application and get stuck on "Starting Alarms". If I reboot the...
1,453
Hi people - I'd appreciate a little help/ information please. We have a new panel as per the title. When I come to downgrade the firmware (as...
1,400
I have a customer who has 20 of our systems using PanelView Plus 7 Performance Series A terminals. With how hard it is to find printer nowadays...
1,625
New PanelView Plus 7 Performance Series B P2711p-t10c22d9p out of the box I went through the touch calibration screen and then to the "Welcome to...
4,899
We're new to using the Panelview Plus 7 Performance Series B panels as the series A is no longer available. FactoryTalk Linx shows it as a yellow...
1,583
