Panelview questions
sweety616 said:
This is how my process is currently working. I have a SLC 5/03 on node 18 of a DH485 network. I also have a SLC 5/05 on node 19 on the same DH485 network. In RSLInx, on this node 19 SLC 5/05, when I click the + button, it shows channel 1 Ethernet.
In RSLinx, under ethernet network, the same SLC 5/05 is present. When I click the + button right next to it, I see Channel 0 DH-485 under which I see 19, SLC 5/05.
I am having a difficulty understanding this set-up. My panelview is borrowing addresses from SLC 5/03 on node 18 of DH485 network. How do I set it up as my panelview is on ethernet. Please help
1 - Change your Panelview IP Address as required (as detailed by others)
2 - For your Ethernet Panelview to "Talk" to the SLC 5/03, you would be using the "Passthru" function/capability of the SLC 5/05...Do you know how to set this up?
You will need to find the "Routing Table" within the SLC 5/05 program..this is found under "Controller", then "Channel Configuration"
You will need to add the IP address of your panelview into this routing table.. You will also need to add the IP address of your PC if you wish to view the DH-485 network in RSLinx
Post back here if you require further help.
how do i reboot the panelview? I cannot get to restart terminal button. I downloaded my application and that is all I see. I cannot get out of that screen to any other screen.
I am thinking about getting an old PV 1000 or something of that nature and was curious about connecting to a SLC 5/04. Currently I have the SLC...
1,892
Hey guys. I've got a Micro850 (2080-LC50-24QVB) and a 7" panelview 800 (2711R-T7T) that I'm working with. I have a couple of issues I'm trying to...
17
11,327
I need to upgrade an old Panelview that went out. The old Panelview uses the PDS software for programming and communicates over RIO to a PLC 5/25...
2,323
Hello, I was wondering if anyone remembers how to use the security section of Panelbuilder32. I'm working with a 2711-B6C2L1, PV600. I can't...
3,011
First of all i just took over support of a large operation and they use alot of different AB HMI's ... the regional mgr wants me to upgrade...
2,070
