Panelview VNC Viewer
Aug 2017
Wisconsin
25
Has anyone ever tried using a VNC Viewer on there panel view to view a different panel view? Wondering if I can get a VNC compatible with windows CE to mimic another panel view.
I would love to know this too :). No contracts with RA :)
Yes it is possible. For this to work you need to make sure Desktop Access is set to Allow on both terminals. Refer to PanelView Plus 6 and PanelView Plus 7: Enabling Desktop Access.
1.Go to My Device and navigate to \Windows\Programs
2.Copy the VNC Viewer shortcut.
3.Paste it on your Desktop.
4.Right-click on the new shortcut and go to Properties
5.Click on the Shortcut tab.
6.Enter the <IP address> of the terminal you are trying to connect to.
7.Click OK.
That Should answer it
Hi All, I am trying to run VNC on my PVP CE. This is not a 6 or a 7. It is just PVP CE.
Logic Module: CAT 2711p-rp6
When i open my Control Panel\Remove Programs, i can only see 2 available applications. FTView ME and FTViewpoint. No VNC.
From watching this video,
https://www.youtube.com/watch?v=s8_GAzgqeyU&t=190s
This PVP has VNC installed. This is confirmed because it has a "Server Config" and "Services" options available in the Control Panel.
The panelview used in this video is :
Screen: 2711p-rdt12c
logic module: 2711p-rp8d
This information confirms that both the video creator and myself am using a PVP from the same family; Just PVP, not 6, not 7.
I have updated my firmware to the latest available firmware; V5.10.16.
Still no VNC.
I have downloaded a VNC for ME from the web, transferred the installation file to the PVP, then attempted to install. No good. I do not think this is possible.
Can anyone please advise what i should do in order to get VNC into my PVP?
Thank you.
Hey James, Thank you for your response.
I have been in communication with the youtube video creator showing the VNC application.
Initially i was under the impression our models of PVP were of the same range. Unfortunately they were not. The PVP range the creator was using, 2711p-rp8d is actually a PVP6. Whereas the model i have; 2711p-rp6, is a PVP only. Not the PVP6.
The creator also advised me, to the best of his knowlege, that users are not able to install programs into their PVP. I presume installation function is locked out.
At this stage, i am of the impression that if i want to use VNC, then i will need to upgrade my PVP module.
I know some of the new panels put out do not have the VNC capability. A job I was just on I was able to use VNC on the MobileView but not on the PVP 7 because it was the wrong series. Maybe check that out too.
TR
Hi All I have just configured a new 2711P-T19C22DP - it needed firmware V12 which I (eventually) got installed, and got my application running. I...
183
Hello, I am dealing with a AB PanelView 5510 device which needs to be accessible via VNC (local only, NO internet access!). To enable the VNC...
2,057
Hello, I have received a PanelView Plus 7 Performance (2711P-T12W22D9P series B) as a replacement for a standard PVP 7. So far I've managed to...
5,029
Hi All! Is it possible to establish any remote access on PanelView Plus 2711P-T10C4D6 (logic module 2711P-RP6)? This panel is running WinCE 4.10...
1,869
Is there a way to see if anyone is using the vnc server, on a panelview plus. I do not want the machine to be started remotely
1,655
