PanelviewPlus 1000 Firmware v4 Compatibilities
MTN
Sep 2015
Calgary
PLC Members,
I’m working with a PVPlus1000 which is currently flashed with firmware 4.0. Since it’s an older panelview it cannot be flashed to a firmware any higher than 5.1 based on what I've researched online (Please correct me if I'm wrong). The project was programmed in Factory View 4.0 also which can only be run on a 32 bit system. To solve this issue I used the legacy conversion tool to open the project in FactoryTalk V8.0. I then created a runtime in the corresponding firmware version of the PVplus1000 (v4.0).
So my question is once I create a runtime for V4.0 will this be compatible in the PanelviewPlus1000 even though it now been converted in FactoryTalk version 8?
Thanks in advance!
Marc
Marc,
I recently did the same thing. Using FactoryTalk v8.0 I modified a project and created a runtime file for V5.10 It was the first time I had done it and was a little nervous but it worked perfectly. Zero problems! (y)
Regards,
Robert
Hello to the community, I am new to Rockwell and I have a small problem with a PvP1000(2711P). Some buttons in the same screen are not...
2,359
Hello, I have a PV+ 1000 that I am unable to access the config screen on. All I want to do is upload the .mer that is currently running. I tried...
21
4,990
Hello, Have same FTView 6 programmed application running on PV+ Firmware 3.1 HMI and running on PV+ Firmware 5.1 HMI. Both connect to ML1000...
1,617
Hello, Have a ML1000 communication via NET ENI module to a PanelView Plus 600 HMI running Ver3.1 firmware. In my FTView 6 I've created and on...
1,957
I would like to have a ( Go To Display Button ) also act like a pushbutton and write a bit to a tag. I have created the tag assigned it to write...
1,272
