randyrjohnson2002
To bkottaras
7. Prints can be on paper up to 24 x 24 so you do not need magnifying glass.
If you need a full plot of a print and NOT BE THE MACHINEST that is going to remake a piece part. You should have that print anyway.
8. Ink on printouts water proof and solvent proof.
Where do you get your manuals that are water and solvent proof?
9. Paper will be flame proof, will not let grease and oil to adhere to it and will be unwrinkled after passing thru a gear or chain drive.
Again where do you get your manuals from? Lol They can run through a gear or chain drive and still be ok? Wow please let the rest of us know your technology please!!!!!
10. Computer will be able to read mechanics mind and give him the page he wants without having to search for it
If the mechanic did a proper job of documentation YES IT DOES READ HIS MIND AND GIVES THE NEXT MECHANIC INSIGHT ON WHAT IS WRONG.
11. Computerized inventory will always be ACCURATE for both number on hand and location.
Computerized inventory WILL BE THE MOST ACCURATE THING IN THERE CRIB!!!!!!!!IF YOU KEEP IT UP TO DATE AND IT ONLY TAKES A FEW MINUTES A DAY!!!!!!!!!!!!
12. Computer is able to find and deliver the right part at the machine
I WILL TAKE A SIMPLE GOLFCART AND PUT TWO ENCODERS ON IT AND WILL PROGRAM IT TO GO ANYWHERE IN YOUR PLANT YOU TELL IT TO GO WITH THE PARTS FOR THE MECHANIC!!!!!!!!! OH SO YES IS THE ANSWER
13 computer will install the part and test run the machine and write the maintenance report.
Again it is all about proper documentation. And no the mechanic is not going to test run that machine anyway. I GARAUNTEE IT IS THE OPERATOR DOING IT!!!!!!!
14. While it is doing all above computer will also ensure the mechanic back at shop is in his lounge chair at right temperature and his coffee cup is always at least half full of coffee or tea at his desired temperature.
EVERY COMPANY IN THE WORLD WOULD LOVE TO HAVE HIS MAINTANENCE PERSONEL SITTING IN CHAIRS PLAYING CARDS!!!!!!!!!!! THAT MEANS THE MACHINES AND PRODUCTION IS GOING!!!!!!! GET A CLUE
I Have to ask. What do you do bkottaras??????????
- All are comfortable and competent with computer.
- All have equal access ?
- Manufacturers supply manuals in both PDF and printed version (for backup)
- Parts lists are in a separate file and each item listed and findable separately.
- Multiple computers throughout plant no farther apart than 1/4 mile to allow mechanics rapid access to manuals
- Each location able to print out desired print or page
