The Plc Kid
Load sharing is one thing, and requires comms between the drives. Separate sources though implies two completely independent drives that will both try to fight to control the same motor.
You would still need fast comms between the two, to keep their outputs exact, which implies one must be a master, which means it's not a redundant system at all, as something (probably bad) will happen if you lose one drive.
Input sync isn't an issue if you intend only to parallel the DC Bus link, but that is only part of what is being asked for here. Even for a computer data center, the usual practice is to simply have a duplicate of every HVAC plant where required for cooling, and only run one at a time.
Parker SSD - /shudder.
Correct it would be a master slave combo and to make it work both drives would have to sized to handle the full load and the software / firmware would have to be able to change master / slave orientation on the fly which i don't know if anyone does that. Example if you load the slave then the master would handle full load and if you load the master the slave would have to switch to master/ single drive mode and handle the full load. I would think that it is do able but i doubt anyone does this is there is very miniaml demand for something like this at best.
Again i don't know. Just kicking around idea's
