parameter access in s7-300 with 22-comm-p
ragavi
Nov 2004
can any body help me to Reading/writting drive pf40 parameters through profibus network.
i have S7-300 plc. cpu 315-2dp connected in profibus via 22-comm-p and power flex 40 drive.
in my hardware configuration i have configured the parameter access module.
i have written the programe to read the parameter
request--->response -----> 0---->0
when send read parameter 22. the following response i am getting. i think this not correct.
request word 1 = 2#0001_0000_0001_0110
response word 1= 2#0001_0000_0111_0110
help me to read the correct parameter.
o_O
i have found that the bytes were getting swapped. so changed the jumper J3 in 22-comm-p to lower position then the problem got solved.
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
83
I'm trying to change some of the parameters on a Yamaha SR1-X-05 robot servo via RS-232, but the unit isn't letting me change them. I can use...
378
Hello, I'm working on a program I migrated from S7 v5.6 to TIA v14. I am failing the consistency checks on my safety program with the following...
20
4,612
Compactlogix PLC I have a totalizator function block that totals flow. There are unusual circumstances where we pause flow momentarily and the...
1,601
Hello, I want to know if it's ok to access the memory of an instance DB (ex. instance DB100 of the FB100 - defined as static parameter in this...
3,679
