Parameter Passing in FTV SE Local Station and Studio 5000
Oct 2022
Indiana
Hi guys. Sorry for the dumb question but I am still new. I have learned to pass Parameters using an HMI tag so far. Can I write directly to the parameter file from the PLC bypassing the HMI tags? I was told that I want to avoid HMI tags PERIOD. I understand how to link it via the HMI Tags. If I can link directly to the PLC, what is the nomenclature? Let's say my linked PLC's shortcut name is MainPLC.
As an aside, I will be accessing the P_AiN AOI. I just learned about AOIs yesterday too so I have a lot to figure out tomorrow at work. The goal is to populate a table with each row being derived from a particular AOI's attributes. The row will consist of the tag name, description, value, if the alarm is enabled, and if it's value is within its defined limits. I am assuming the P_AiN AOI shall contain all of these attributes. I will verify first thing in the morning.
Thank you for your help!
I inherited a project in which a ME application displays process measurements (temp, pressure, flow, etc) on a PanelView Plus display. The data...
496
Hi guys, A dumb question, but is it possible to pass values to tags using parameter files in Ftview SE ver 11? TIA
1,464
Is there anyway to pass a parameter file without using a Go To Screen button in FactoryTalk View ME? I am currently using multiple Go-To buttons...
1,631
Hello I am trying to have one screen that has one trend, that I can have an operator select what tag to trend. IE I am trending a bit shift, a...
1,168
i wanted to create a small project using parameter List using an example listed in the factorytalk view manual. in the display list selector...
6,283
