Parameters in visibility expressions FTView SE
scopley
May 2017
iowa
Using Parameters set to 1 or 0 for button visibility
I want to use a parameter in the visibility expression for button on my menu, what I'm doing isn't working.
I want to open a menu display and pass though a parameter file with it to determine which buttons on the menu display will be visible. So far I am passing through values like this:
#201=1
and then on the menu display I set the visibility animation expression for a button to {#201}. Intending for it to be visible when #201 = 1 and invisible when #201 = 0.
I know I'm passing the par file through to the display when it is being called but the way I have it set up still isn't working. Does anyone have a better way to do this?
I'm getting an errors "Failed to resolve item's ID '1' because it does not exist on any server" and "[FactoryTalk]: The Item is no longer available:#201."
Thanks in advance.
Go to HMI tags/tags/literals, call the first one "true", select digital, data source memory, retentive, initial value one. Then do the same for "false", but initial value zero. Reference the tag names in your parameter file.
thanks this worked
thanks, this worked. Searched around a bit too and seems others have had this same issue and solved it the same way. thanks
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
99
I'm using FactoryTalk ME version 13. I'm aware how to pass a parameter file once, but I was wondering if it is possible to do it twice...
162
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
145
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
101
How do I adjust motion control parameters using Logix Designer? Such as: motion axis stop I will make an adjustment like changing the...
324
