Parker CTC Interact v7 Exclamation Point Error
delforum
Jul 2014
US
Hello Mr PLC Experts,
I am working with a Parker CTC application on XP in VMWare. I am trying to modify and existing project and now it is not displaying correctly on the Parker CTC HMI from the CF card. When I load the project back to the screen, some of the real numbers I am passing do not display their values in the ethernet linked AB CompactLogix PLC. They instead read zero and have and exclamation point in front of them. Some of the tags display OK.
Have you seen this before? Any suggestions?
Thanks, Del
I am taking over a CTC Interact project. All I have to start with is the LRP file. I do not know what version it was written in. It was done...
1,826
Hi, I have an old unit HMI with model PA10T-133 (PA Powerstations series). 1. I just have an inquiry whether which particular software to use...
1,835
We are kinda stuck with this HMI (since Parker is pretty new for me). We are trying to set communications with an OLD Siemens S5 115U CPU. The...
1,874
I installed a new Direct Soft 205 Series/240 PLC in a CTC Turret. The turret uses an interactive CTC/Parker touch screen. After installing the...
2,411
Hello!:confused: One of our clients is having a some problems with a touch screen CTC-Parker P11-314DR, he says he can't access to his HMI...
5,873
