Partial import / export of tasks in Control Logix
Mr Modbus
Jan 2014
Lincoln
24
I am aware that in Control Logix that you can export the projects and elements of the projects. So what I would like to do is to take some external structured text files and produce a program from them. I would be starting with a blank project that just has the hardware defined. I then want to import a file that sets up a cyclic task and also a program within that task. I can then import the structured text into this program.
I could not see any option to just export the task / program, so
my initial attempts to find a way was to define the task and program that I required and then export the whole project to an l5k file. I then deleted everything in the file except the TASK and PROGRAM sections. I then tried to import this. However, it did not work as it gave me an "invalid data type" error at line 3. Is it possible to just export / import the tasks / programs without the rest of the project data?
(my experimental file is shown below)
IE_VER := 2.8;
PROGRAM TESTS (MODE := 0,
DisableFlag := 0)
TAG
END_TAG
END_PROGRAM
TASK Cyc10ms (Description := "10ms cyclic",
Type := PERIODIC,
Rate := 10,
Priority := 1,
Watchdog := 10,
DisableUpdateOutputs := No,
InhibitTask := No)
TESTS;
END_TASK
Why are you using import? You can just cut/copy/paste routines/tasks from one CLX program to another.
I could if I was transferring code from a CLX system. However, it is being transferred from a Simatic S7 system.
Yes I know that the code will not compile without some work.
I am going to write an "interpreter" that converts S7 SCL to CLX structured text. But I obviously want to import this converted structured text into the CLX system.
In the S7 system, I can make a cyclic task (OB in Simatic speak) from SCL code, and I was looking for something similar on the CLX system. So I was looking for a way of defining a cyclic task, and a program within that task using an import file. But I only want to make the cyclic task and program, not the whole controller code as my starting point will be a project that already has the hardware part defined.
Hello. This one is as nerdy as it can get. Never seen this issue before. I am seeing a "Partial Network Fault", for which the specification only...
3,055
Hi Everyone, I'm working on a PLC-5 program offline that I've modified several files on - adding rungs or branches to rungs. No data table...
2,622
Good Morning , I'm using FactoryTalk / ME and I have a Piloted List Selector that I have the recipes that the operator chooses from. On...
1,742
I have a customer with an old pump panel which uses autotransformer style reduced voltage starter. I have worked with wye/delta starters, but...
1,715
Dear, Pipe size is 1200mm and I need to install sensor for measuring flow, I check krohne and Toshiba for electromagnetic flowmeter for partial...
4,240
