PCB Coating
bitmonkey
Oct 2015
Ohio
94
I notice that a lot of printed circuit boards have a clear coating on part or all of the board. Can anyone tell me what it Is and is that something that can be bought in an aerosol can?
I can't say exactly what Rockwell uses, but I do know that it's principally to protect against tropical humidity and corrosive atmospheres.
My understanding is that the goal is to meet the "G3" level of the ANSI S71.04 standard for corrosive atmospheres.
Yes, conformal coating.
The type I used while doing repair work was mostly acrylic to seal. Unless the board was previously sealed with silicone, so I could match the thickness up to look like factory.
But if you use epoxy or silicone and the board comes back on warranty it is harder to access your components again.
Yes you can buy in spray cans.
Sometimes I see that a thermal overload relay (combined with a protection against short circuits) is used instead of a MPCB (motor protection...
919
Hello, I have recently started at a new company and currently in charge of setting up the tolerances for our AOI(s) to judge all of our many...
1,076
Hi Guys, Is there anybody here who have a new recently (since 2015) bought S7-1212C preferably 6ES7211-1BE40-0XB0 CPU? I need a picture of its...
2,037
Any recommendations and suggestions for reverse engineering legacy PCB and converting to PLC system? All we have is the physical equipment, the...
1,686
Hi, How to select MPCB(Motor protection circuit breaker) for inverter?
2,548
