PCB Manufacturing
Apr 2021
USA
Hello, I have recently started at a new company and currently in charge of setting up the tolerances for our AOI(s) to judge all of our many different PCBs. I got thrown into this and was wondering if anyone had any tips or suggestions for the settings of different components; we are using IPC class 2. Any help would be appreciated.
Thanks,
I worked in a PCB shop for a little too long. [Beware of any PCB shops named after objects in the solar system]
The best way, because different boards will have different tolerances, is to set up the AOI's with tags and have each PCB job have its own recipe.
The recipe UDT would be:
Job Number
Square Feet of Cu per panel
Tolerance_1
Tolerance_2
Tolerance_3...........
Return parameters of:
Pass_1
Pass_2
Pass_3............
Sometimes I see that a thermal overload relay (combined with a protection against short circuits) is used instead of a MPCB (motor protection...
911
I notice that a lot of printed circuit boards have a clear coating on part or all of the board. Can anyone tell me what it Is and is that...
2,192
Hi Guys, Is there anybody here who have a new recently (since 2015) bought S7-1212C preferably 6ES7211-1BE40-0XB0 CPU? I need a picture of its...
2,036
Any recommendations and suggestions for reverse engineering legacy PCB and converting to PLC system? All we have is the physical equipment, the...
1,679
Hi, How to select MPCB(Motor protection circuit breaker) for inverter?
2,547
