PCS7 Engineering station VM ware clone comms problem
Krcedinac
Jul 2006
Krca
163
Hello to all,
I converted ES to VM ware workstation virtual machine via VM ware convertor. Adjusted all necessary parameters like new IE General settings etc.
Communication between AS and CFC works but WinCC runtime does not communicate to AS. Compiled many times tried everything I know but without results.
Version of PCS7 is v7.0 + SP1.
What can be the reason?
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
138
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
494
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
817
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,569
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,944
