PCS7 is DCS or PLC?
recently I had been to Siemens Automation Road show. there they have explained only the software part of it. the Programming follows IEC61113-3 like ladder, FBD,STL etc. The software more or less like DCS software where all HMI screens more or less standard and less generic in nature. There are no of modules but they have not given any cost difference. Siemens recommends mostly for process applications only. I feel it is a hybrid in nature.
PCS7 isn't PLC. It's DCS, area-oriented multi-node system. PLC and SCADA program are highly integrated - main SCADA objects are derived from PLC program and block templates. After project compilation SCADA tags, screens and devices icons are generated automatically. But, of course, programmer must to design another graphic himself.
STL, LAD, FBD aren't used in most cases in PCS7. Blocks templates are in CFC form. PCS7 is oriented to SFC and CFC using.
All it seems very good but I'm f..ng with PCS7 now and don't sink it's good.:)
Is it possible to communicate with Foxboro DCS (CP60) using PCS7 or any other DCS or PLC.
2,051
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
141
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
497
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
819
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,570
