pdf file in panelview plus 700
tano71
Dec 2009
diano d'alba
Hello,
I starting to work with FactoryTalk View Studio.
I'm programing an PanelView Plus 700 (2711P-T7C4D9) without big problems,
One thinks that I can't do is to open a PDF file.
I try to use the activX control, so my quastions are the following:
PDF file I'm starting to work with FactoryTalk View Studio. I'm programing a PanelView Plus 700 (2711P-T7C4D9) without big problems,
One thinks that I can't do is to open a PDF file. I'm trying to use the activX control, so my questions are the following:
1. - I need to use ME Program launcher or Adobe PDF reader?
2. - How can I download the file PDF to the panel or I need to put this PDF file in a USB or CF Card.
3. - The panel is a Windows CE panel, then, it is possible to open Windows CE on the panel or not? I used the simulation of FactoryTalk View Studio and was possible to open a PDF file
For example I used the ME Program launcher activX control with the followinfg settings:
- Program Location ="C:\Programmi\Adobe\Reader 10.0\Reader\AcroRd32.exe"
- ProgramParameter = "C:\2012E395.pdf"
- FocusEnable = 0
- NewIntance: = 0
But I don't now how to do when iI will do the same think but using the Panel.
Tank a lot for the help
Best Regards
Alejandro
the panelview plus terminal is proframmed using the software you mentioned. the application file when you program it is a .apa file and is converted to a .mer file when it it downloaded.
i am unaware of it being able to use a pdf file for the application.
regards,
james
Hi, I am using PanelView Plus 1500. I want to open a PDF file i.e. saved in local through a button. Should I use Macro for this ? Thanks...
1,207
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
125
Hi All, I have several ACD files & L5X files, I would like to read the contents of these files, however I do not have Rockwell Studio 5000...
2,322
Hi, I'm trying to send PDF screenshots from my 1500 comfort panel HMI to a specific folder in an IPC that is connected on the same network. It is...
2,420
Hello Could you advise, how to convert AB program(.rsp PLC5) to pdf? Thanks
4,916
