PF525 connecting with CCW software
forqnc
Jul 2009
Elizabeth City
148
I am trying to get familiar with Allen Bradley PowerFlex drives. I have the latest version of CCW (v12) installed. I just bought a drive from EBay, brand new in the box, sticker shows firmware 6.001. I can setup the parameters in CCW but the software only goes to version 5. When I try to download my parameter file I get a popup saying the drive is version 6. Does anyone know If I am OK to download my version 5 file or will I create a brick.
I have just downloaded the latest CCW (this morning) from RA, it installed some newer components but still won't allow me to select above v 5.
Any assistance is appreciated.
Thanks for the reply Ken.
I found a work around.
I set the drive Ethernet parameters manually.
Then connected via Ethernet and uploaded the default file.
Once the default file upload it now displays 6 in my versions and I am able to go backwards.
But..
When I start a new project I can only select version 6 for the same voltage and HP drive as I downloaded.
To select another Volt/HP setup I need to go back to version 5.
Controllogix L62 RSLogix 5000 v:20.11 I have configured several PF525 in my project, but the latest one won't connect and I can't figure out...
1,885
I seem to be on here often lately but cant find specifics about my situation I am trying to control the drive using both ethernet and analog(for...
749
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,010
Hello all, New to this site - I am adding a new conveyor and using a powerflex 525, though the rest of the drives operating this line are...
1,287
I have a (*) PowerFlex 525 being supplied with 400VAC, 60 cycle, 3-phase. This is not a type-o, this is accurate. Now, the drive clearly states...
1,181
