PF525 Down load /Upload
Racer5039
Oct 2014
midwest
77
If I down load (using the USB port) from a PF525 and when loading it into a new PF525, will I need to change the Rev number in the file to match the new drive? This is just the first couple of lines from the down load.
?xml version="1.0" encoding="utf-8"?>
<Node>
<Drive Brand="1" Family="9" Config="198" MajorRev="3" MinorRev="1">
<Parameters>
<Node>
<Parameters>
My understanding is that there is no manual manipulation of the drive upload files required.
Simply download to new drive and the drive does the rest.
Did you check first to make sure your two drives have the same firmware revision? That's how I interpret what you are reading. One drive is a different version than the other and the parameter list is not the same. You can update firmware on that same port.
I have successfully modified the file to match versions. However, you must use Notepad or another text editor that is compatible. The first time I used Wordpad and that corrupts the file.
Yes, I found that out also.
SO all I would need to do would be copy and past the perimeters and paste them into the file I uploaded.
Working on setting up files for the other shifts that dont have hands on of 5000 but would be able to use the USB to config a drive if/ when a failure occurs.
Thanks for the feed back.
Hi all, it seems that the Rockwell PCDC is down for the next 2-3 days, and I need some firmware files for a powerflex 525, v7.001. Does anyone...
2,184
I seem to be on here often lately but cant find specifics about my situation I am trying to control the drive using both ethernet and analog(for...
756
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,021
Hello all, New to this site - I am adding a new conveyor and using a powerflex 525, though the rest of the drives operating this line are...
1,300
I have a (*) PowerFlex 525 being supplied with 400VAC, 60 cycle, 3-phase. This is not a type-o, this is accurate. Now, the drive clearly states...
1,198
