PF525 to a PanelView Plus
alan_505
Feb 2007
Melbourne,Victoria,Australia
1,045
Has anyone had any success using a PanelView Plus to directly control a PF525 over ethernet, I tried to use the file provided with TechNote QA52360, but have been unable to get the communication path to work.
I am using a version 11 PanelView Plus 7.
Just a follow up, after chatting with Rockwell Tech Support.
It was determined that the TechNote was incomplete, Once I selected a 1747-L531 from the "NetENI-connected PCCC" devices folder and created my MER file it was able to control the PF525.
I seem to be on here often lately but cant find specifics about my situation I am trying to control the drive using both ethernet and analog(for...
749
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,013
Hello all, New to this site - I am adding a new conveyor and using a powerflex 525, though the rest of the drives operating this line are...
1,290
I have a (*) PowerFlex 525 being supplied with 400VAC, 60 cycle, 3-phase. This is not a type-o, this is accurate. Now, the drive clearly states...
1,184
Hello All, I have a PF525 that the speed ref 1 is set to "Drive Pot" and speed ref 2 is set to "Keypad". I need to drive a motor at a rapid and a...
1,887
