PF70 Remote HIM
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
I am modifying some old Square D MCC "bucket drives" getting rid of the Altivar drives and installing Powerflex 70 in their places. The 2HP drives I am using have a removable face which holds the HIM cradle and on the bottom is a connector for a scanport cable to accomodate a remote HIM.
I would like to use a remote HIM on the door of each bucket, but there is a clearance issue with the remote HIM cable which appears to be the same scanport cable that A/B has used since the 13xx series drives. Just below each drive, there is a plug in terminal block mounted to the bottom of each MCC module that I really can't relocate, so the A/B cable (p/n 1202-H10) won't quite work.
Does anyone know of a scanport cable with a right angle connector on one end, or of a remote HIM option that doesn't use a cable that sticks out below the edge of the so far?
I had hoped there was a cable that plugged directly into the HIM cradle connector, but I have not found anything like that. They all appear to be the round scanport type connectors, and all are straight as well.
Probably a long shot, but it never hurts to ask.
TIA,
Paul
Although SCANPort/DPI and MicroLogix cables are both in Mini-DIN8 shells, they have different keying and pin patterns. You can't take a right-angle 1761-CBL-PM02 or similar cable and cut the end off to make it fit a DPI device.
I can't think of a solution for this; all the DPI cables I see are straight shells.
RA may have some special cables that you can't order with a 1202-xxx part number, though. See if the low-voltage drives manager at your regional RA office can help you out.
Sounds like you've been there Ken. It was worth a shot. Dory to get your hopes up Paul.
Hello all, New to this site - I am adding a new conveyor and using a powerflex 525, though the rest of the drives operating this line are...
1,304
Hello, I am modifying a program for a 1756-L61 controller using Logix version 20.01. I am trying to add or change datalinks for several of...
1,541
Slightly off topic here. We have a new Emerson PK controller and need to communicate to a PowerFlex 70 over Ethernet/IP. Now we’ve done this with...
1,303
Hi, I have upgraded some drives from 1336Plus to Powerflex70, The drives are on an RIO network. Tidied up PLC code and configs to get the drives...
3,258
Hello I’m faced with an task of replacing a VFD with external brake resistor, the original drive is a UNIDRIVE 1405 and it’s obsolete. The VFD...
3,628
