PIC driver query?
Soggy Canuck
Jan 2008
Vancouver
229
Good morning all,
I have a situation with a laptop running XP pro with RS Linx ver. 2.51.00.21(CPR 7). It has been very stable up until my computer went off and loaded XP SP3. At first I had no problems with anything in my AB suite, until I went to talk to an old SLC 5/00 with my handy PIC driver, only to find that the driver would not load, perusing the AB knowledgebase I found the bulletin about SP3 not being compatible and promptly removed it. I can now load the PIC-1747 diver and can see the PLC in the RS Who window. When I open RS Logix 500 and attempt to go online it tries to connect and faults out with a communication loss error message. As an experiment I tried downloading the code using the RS Linx viewer and it pulled the code out but would not stay online. I am assuming there is some other update that I need to find and remove. Does anyone have any ideas on how to figure out which update is the offending one. I can roll back the laptop to a previous save point but am not willing to stop downloading all of the security patches from Microsoft just to keep one old driver going.
Regards Soggy
Just a thought, but could you not partion your drive, and dual boot with an older copy of windoze just for running the older software for the older PLCs?
I could give that a try, i've got a copy of '98 lying around here somewhere, If I can track it down I will have a go at it.
Im getting trouble with my plc using 1747 pic connection, i found this solution: http://www.plctalk.net/qanda/archive/index.php/t-63919.html, but...
2,253
Hello everyone, I received a Fatal error message when added driver 1747-PIC, after that I closed that window and driver was added normally, but...
2,152
I've been searching and have tried everything. I can currently connect to a SLC 5/03 using RS-232; however, I want to test the RS-485 connection...
3,810
Hello, I am running Windows XP SP2 and Rslinx does not have the 1747 PIC AIC+ driver available. Not showing up on driver list/selections. Is...
4,082
Let me start off by saying I know I need to get a 1747-UIC, but I can't get one in for a couple days and I'm working on something time sensitive...
9,498
