Pico 1760-ldf+1760-ib12x0w410f
devidie
Feb 2014
portugal
I have a pico 1760-LDF+1760-IB12X0W410F, and i need to do basic arithmetic functions: addition, subtraction, multiplication and division. But this 1760-LDF+1760-IB12X0W410F, this didn´t save a decimal number.
Example if i made 5/2=2,5 , but in 1760-LDF+1760-IB12X0W410F, 5/2=2 and arcy carry =1. I need know, how can get the 0,5; if this is possible. I didn´t know, how to use numbers as PI.
Regrats Devidie
Seems there are no arithmetic functions on this device as it is little more than a glorified timer ...
QUOTE:
Pico is a compact, user-friendly and low-cost controller for simple control applications. Applications range from building and domestic automation to machine and plant control. Pico has built-in user-friendly operating elements and an LCD display.
Connect Pico and draw a circuit diagram on the display by pressing the buttons on the device. Pico works with make contacts, break contacts, and relays.
Enter a circuit diagram in Pico just like it is sketched on paper. Pico has basic and advanced functions for relays, time switches and contactors, among other functions. Make changes to the circuit by pressing the buttons on the device. Time consuming rewiring is not necessary.​
Hi im trying to connect my pico to my laptop but I cant configure the com port for usb. it works okay on a different laptop with the serial cable...
2,066
Hello to all, first I want to say that I know nothing about plcs I leave it to the properly trained! I am a residental and commercial...
2,167
Can this controller output a closed switch with NO voltage? The autostart on this Kubota genset only requires a jumper (switch) between two...
2,554
Can anybody out there give me the pin-out diagrams for Allen-Bradley Pico programming cable. I believe the correct # is 1760-cb02. I have not...
2,666
Hello, I'm new to this forum, so bare with me. I am working with a PICO controller, the 1760-L12BWB Series A. I have run into two problems...
5,445
